Engine dent in oil pan
Manic Mechanic
Full Time Jeeper
Gold Supporter
Featured
Thurmont MD
85 CJ7 4.2L 258 .040 over, T-5 trans, dana 300, dana 30 front 3.23 and lock right locker, rear amc 20 3.23 one piece axle shafts traclock
79 CJ7 304, th400 auto borgwarner 1389?? qudratrac stock rest unknown.
89 YJ 4.2L 258, AX-15 5spd, NP231, dana 30 front, dana 35 rear with posi, gears unknown
92 YJ 4.0, AX-15 5spd, np231, dana 30 front, dana 35 rear.
so my old oil pan had a dent in it that i assumed came from my worn out front drive shaft wobbling around. well i now have a new driveshaft and a new oil pan (attached to a new motor) (long story) well after less than 600 miles on the new motor and only one short small off road trip i now have another dent in my new oil pan in the same spot as the old one. something is obliviously hitting it but im not sure what. before you ask i have brand new polyurethane motor mounts and yes theyre tight. im not sure what is hitting the pan rather its the pinion drive shaft or what but obliviously nothing should be contacting the pan to begin with
Shot in the dark here, shouldn't the bump stops keep the axle from going that high? Do you have a lift ? Were the bump stops extended? Do the bump stops look like they have been getting hit?
You mentioned a new motor - what type, mounted differently, etc? When I installed my SBC with 70R4 tranny, I needed to offset the motor to one side just slightly, and also use a thinner front drive shaft, to avoid this very issue. Also echoing "yellow85cj" that perhaps the bump stop for the front axle needs investigating/extending.
just another AMC 258 i6 / 4.2l i had laying around. direct swap
Sent from my E6810 using Tapatalk
I did that very thing and the skid plate was grabbed by the yoke. My bump stop was loose on the right when it happened. Pretty sure that allowed the shaft to slop left on deflection.
Engine Oil
