Does this look right? (is it broken?)
cyberworm
- Venice CA
- 1984 CJ7 258 I6 Carter 2BBL. 33" Hercules Trail Digger M/T 6" spring lift D300/T15. Aluminum Valve Cover.
Hello!!!
I'm having problems with my CJ7 idling, hesitating, stalling, and spitting gas out of the exhaust. Had her timing checked, and installed new plugs. Still having the same issues. I don't know much about engines, but after having watched the carburator being tweaked and worked on to try and figure out the problem, I went out and played with it a little bit, to see if maybe I could find something that wasn't working right.
So, with a friend handy we started looking around, following vacuum hoses from their sources etc. Finally, I started to look at the carb and play with the throttle a bit. My friend (who is way taller than I am), says "that thing looks broken." It looks like a plastic lever, that is attached to what I am going to call "the choke plate"by means of a little metal rod, and from what I can tell, should maybe have some sort of spring attached to it since there is a spring loaded screw that looks like it should be touching it. The thing is just dangling there not doing much of anything, nor is the rod that is attached to the "choke plate." I played around a bit with what I would guess is the fuel/air mixture and the throttle, so I think (hoping) that I'm on the right track, with my basic knowledge of how these things function.
Attached are some photos, if anyone has any good photos of this carburetor, or can tell by looking, if this piece is broken, I'd appreciate it. It's a 6cyl AMC 258 i6 / 4.2l 2bbd.
The factory specs are for a brand new motor when you get wear on stuff like your timming chain it just becomes a base to go from.
