Doing a Ax15,and YJ Booster Swap
I really am having a good time watching this thread evolve.
You are doing a great job with both the adaption of the tranny and with the documentation of everything, including the walls that keep coming up and you have to find a way to climb over them. I applaud you for the stark honesty in which you are showing in listing everything good and bad.
I want to thank you for this, it will be a valuable thread for anyone doing any thread to read as it shows what you need to deal with and how you have to source answers.
thanks again for this thread.:chug:
THanks BAJA that makes me glad I posted this Info I wanted it to be helpful and wanted to answer all the questions I had going into the swap. It may be too late to celebrate because the CJ wont idle now and after I messed with it for a while it started trying to start in ACC on:eek: I cant think of how the Tranny would cause this issue but the truck ran engine wise when I parked it to pull the T-5 :mad:
If you want Honesty:
You can save a whole lot of time by having the the right parts and and working area. There is no slab her to work on and the ground is too soft to jack the truck up so I have been doing this with the lift from 31 tires.
Also you have to buy the AA ax15 to Dana 300 sealed bearing and clocking kit. You may be able to get away with not using the clocking ring and resell the clocking ring but if you dont get the sealed bearing then oil will pass from tc to tranny and tranny to tc because the Dana 300 originally made a seal through the other means.
Those were the things that slowed me down the most. Oh and I put off doing the clutch linkages this whole time because I was confused how it worked and thought I was going to have to do all sorts of craziness to get it to work and it ended up being super simple and I should have taken care of it while I waited for the clocking ring.:chug:
I echo Baja here, you have done one hell of a write up :chug: :notworthy: :chug:
So this is frustrating, yesterday I tried the front driveshaft. It looks like once j get a new one it will clear the cross member but looks like it is going to be a pig's but hair awAy from from the belhousing if not touching he housing. Also the ax15 is well over 2 or three inches longer. I clocked the tc at paralell to the ground because it surprisingly cleared the floor board but now it looks like that is bitting me in the <-BAD WORD-> because the angle is two high to give the ds and room to flex upward. Now I have to pull the tc of and remove all the studs and try clocking it lower or maybe take some metal off the BH. Anyone have any suggestions here?
Ok I am not happy about the drive shaft Issue. I am going to pull down the tc tomorrow or wed And clock it two or three positions lower. If I have to gring the shifter assembly so be it.:mad:
I couldn't resist the urge any longer and got ordered a twin Stick to go with the Dana. There is a shop on eBay sellin em for 90 something after shifting and comes with knobs and the boot. U figured since this project is being such a time consuming pain I might as well add more complication. I will probably never use it but hey at least I'll have it.
I called AA this afternoon and popped the question" have ya'll commonly had issues with bellhousing clearence on the front driveshaft." The answer I got was all the time. So I was told to buy their motor mount kit that offsets the engine... No thank you. Maybe if you are planning for some hardcore stuff this is a good solution but just want to fix this up to be a nice cj.
I am wondering if it would affect the integrity of the belhousing to shave some material off for drive shaft clearence. I'd imagne that if you were doing any hardcore off roading you would have a much bigger lift so the clearnce would not be an issue and for that matter you probably wouldn't be installing a five speed anyhow. I may try to get some new stock height springs as these seem to be sagging or maybe some 1.5 inch springs from Rusty's.
Well I has a major set back today. I had a major fuel delivery issue halfway though this project and today when I thought I was ready to make my first road drive and was trying to tune the carb and timing for, the hydraulic linkage found it's way to the exhaust pipe. Melted right through it. So now I am grounded again till I can source the hose from the pick-n-pull or heaven forbid mopar:eek::censored
I am pretty aggravated by this.
Also a local guy that is a huge cj fan and owns like six came buy to get some parts and told me that I made a huge mistake in my placement of the master cylinder. He claims I need to find a yj clutch pedal and then punch out the hole a tad higher (there is a pre stamped hole for 4banger cjs) and everything should link up. I may do this eventually as it does seem smarter but for now I got a lot more pressing issues that moving the mc upwards to lengthen the throw
