Drive shaft lube
Drive shaft lube
yellow85cj
Featured
Ft Worth,TX
85 CJ7, 258,4.0 head, T177, D300, Dana 30, AMC 20, 3.54
Same grease I use in the joints...Molybdenum disulfide (Moly grease)
I would clean the rust off with some scotchbright.
Same grease you used to lube the ball-joints etc.
On the short end of the driveshaft there could be a small hole, if so you can put your finger over that hole as you fill it with grease. This will allow you to really fill up that seal.
