Front drive flange
Just order a set of Miler Marker hubs, and all will be good.
MM is the best out there-The only hubs that have held up to the D/L in my '30'.
Not made out of the Zincthe Warn is.
Absolutely!
I'll be swapping out my Warns for MM when I put the locker up front.
Absolutely!
And use a threaded stud set-up in the wheel hub also.
Go with the stage 8 bolt kit forget about doing studs. I run them in my jeep work awesome.
https://www.stage8.com/off-road-locking-fasteners/off-road-manual-locking-hub-fasteners/
The studs save the wear and tear on the cast iron threads of the wheel hub.
The studs and nuts should be at least Gd-5.
Torque the nuts to 30-35 ft/lbs.
The cheap zinc used in Warn hubs just compresses under torque of the nut, and that is why they don't stay tight.
Looked at that Link, It's just a way to keep the nuts from backing off, correct? So is loctite a bad option?
Yes they keep the bolts from backing off. I wheeled in moab for a week and never had them come loose. Before I bought the stage 8 locking bolts I had a set of these. https://walcks4wd.com/lock-out-hub-lock-washer-kit-warn-hub-only.html They work great but wanted to try something else because they wear out after a few time of bending them. Loctite has never worked that great for me on hubs.
