Jeep is frozen, Help!!
sarfu
- Point Pleasant, NJ
- 1974, CJ5, 304 V8
Renegade Yellow
T-15 Transmission
Dana 20 T. Case
Dana 30 Front Axle
Dana 44 Rear Axle
I can turn the front drive shaft by hand, all wheels turn by hand when jacked, rear driveshaft only turns in neutral. when I shift my Transfer Case it seems to be binding and not really moving smoothly through the gears.
Everything was working fine last weekend, did not touch the T case shifter, jacked the vehicle and did all four drum brakes, finished the job, got in the jeep to test the brakes and it would not budge in neutral or in gear, I tried letting out the clutch and giving it some gas and the engine stalled. everything on the Jeep is pretty much stock, I have not done any mods to it.
I want to try jacking the rear and putting it into first gear, but my battery died, so I will have to try tomorrow
No kidding, I am totally stumped, I had no issues before the brake job.
