Build Thread Jr's 74 CJ5 "fix" and build as I go...
I see what you guys are saying. I'll take some measurements in the garage tonight. I'll take some good pictures of everything too to show what the kit all came with.
The new spring plates have like a double bottom plate to recess the bolts and nuts into the plate. (there's gap between the two plates) hard to describe, but it looks pretty trick. I'll check out the measurements of the shocks, and then the measurements I should need with the "kit mounting" positions and measurements I should need if i do the top of axle mount like you guys are saying too. See if the shocks work for either of them, and go from there.
I'll post some pictures of it all tonight / tomorrow.
First things first, does anyone have good link to detailed Dana 20 rebuild? I have a good idea, but like to look over a few before doing it.
I've searched around a bit, but haven't found one besides pirate where hes doing a bunch of different stuff...
~ Jr
First things first, does anyone have good link to detailed dana 20 rebuild? I have a good idea, but like to look over a few before doing it.
~ Jr
:)Dana 20 Transfer Case ..........where did you get the rebuild kit from? Novak has instructions online in fact you should buy one of there HD 1.250" cross shafts for the rebuild if you don't already have one. I've got some good reference material around here somewhere send me a PM with your e-mail and I'll find it and scan it for you. You also need some special assembly lube, the type I get I put it in the freezer overnight so it is firm and holds the needle bearings during assembly.
:D:D:D:D
Nice!
I did get the kit as well as instructions from Novak.
I'll pm you my email now.
Cheers
~ Jr
Nice!
Cheers
~ Jr
:)I found some of it I'll get it scanned here tonight or in the AM and send it to you.
:D:D:D:D
~ Jr
Jr. just to be sure we are talking the same, the mount goes on the back side of the axle, high enough to get the shock above the bottom of the axle.
I went out and took a pic.
:)Did you use one of there 1.250" special cross shafts with the o-ring on it?
Yes! Got the new intermediate shaft with the o-ring seals :D:D
As far as your flywheel, take a big screw driver or bar and wedge it into the ring gear teeth and a bolt or dowel in the back of the block.........that should hold it. Or if you have a good 1/2" drive air gun that will also take them off.
:D:D:D:D
Going to try the air impact... We had the compressor's cord at work for some welding we were doing. Should be able to get it back off in the next day or so.
I've done the tooth holding thing in the past, but wanted to avoid it if possible...
:cool::cool:
~ Jr
With how far your into it Id be tempted to just pull the engine , regasket and paint it right away. Then while the engine is out clean up the firewall and inner fenders , then... :D
the "then" is what I'm afraid of... :eek:;)don't have the money to build the new frame and new dash and re-wire the jeep and rebuild the AMC 304 how I want to and........
lol :drool:
I just need to get her back operational for a while, before she ends up parts in my garage for years...
~ Jr
~ Jr
:eek: Don't let that happen.:D Just keep chugg'n along, you'll have it done in no time. :chug: Just remember "it's a jeep thing"
Just giving you :dung:. I want to see it back out on the trail for you. I cant wait to here you gush about the new Transmission and lift. :chug:
the "then" is what I'm afraid of... :eek:;)don't have the money to build the new frame and new dash and re-wire the jeep and rebuild the 304 how I want to and........
lol :drool:
~ Jr
soon :drool::drool::drool::drool:
:D:D
~ Jr
Ok school me on the Hydraulic clutch install. Is it mainly to get rid of the pop apart bell crank linkage? It seems like alot of work to me. Im probably missing something.
you got it... a lot of work, but i really hate having my clutch linkage screw up on the trail and it seemed to put a lot of stress on my clutch disc too at times, just a theory but makes me wonder if it helped burnout my clutch disc too...
I'd get twisted on some rocks though and the clutch would not disengage enough to change gears and at the same time, would not hold enough to still go forward...
This is also supposed to be a nice smooth operation and not as stiff as some cable conversions can be. I remember reading about the chain conversion which looked sweet from advanced adapters, but thought it was kinda exposed...
So I went with hydraulic instead.
I had changed and tweaked on the linkage enough and this last trip made my mind up for me... I was done with linkage...
I'MMMM BAAAAACCKKK!
:D:D
Been busy as all :censored: with a new position at work!
Keeping me busy my 50hrs / week.
I'm still going through some issues with my Novak order that I am hoping to have sorted out in this next week and a half before my next open jeep working on weekend!
I'll have some updates soon!
~ Jr
$150.00
  75.0%
