keys left in and Jeep is dead
Do you have a manual? If not, you need to purchase one as it will help explain replacing parts and diagnosing many of your problems...![]()
I highly doubt you will need to replace any tubular fuel lines. If anything maybe some of the rubber lines got brittle and leaked.I've been looking at new fuel lines and tanks just in case. I'm thinking I'll go with a braided steel one instead of the thin metal tube that's there now...if I have to.
Yes, replacing the pump is easy. That arm presses agenst the cam. You can't hardly get it in wrong.The video I saw had the pin inside the shaft propped up and the lever slid in below that--is that how my new one will go in?
do you have a manual? If not, you need to purchase one as it will help explain replacing parts and diagnosing many of your problems...![]()
The battery was dead and I got it charged and it still wouldn't crank. Then I got a new battery and it would crank but not start. Than checked inside the dist. cap and found out (thanks to CJ) that I have no points at all but a Duraspark. Then checked for spark and saw a small yellow one. Then tried starter fluid and it fired right up. Checked the fuel going to the filter and some came out while cranking...not after the filter though. Changed the filter and still not enough fuel. I have a new fuel pup on order. I'll change that when it arrives and hopefully that will work!Hi Jessica! Looks like you've received nine pages of responses so far! Wow!
I'm a little confused. If memory serves, weren't you saying in the other thread that you didn't have any spark after leaving the key on? I take it you've since found that you don't have fuel getting to your carb instead?
It took a few attempts to start it unless the engine was warmed up. With the starter fluid it starts immediately. Not sure if that was the pump dying or a completely different problem.Without reading all nine pages, would you mind giving a quick summary of what you've checked and done? How did it run before leaving the key on all night?
The weather is GREAT right now! It's the sunny dry season which is why I've been trying so hard to get the Jeep working. Soon it will be too hot and raining everyday... I live very close to Marco Island by Collier and 41.P.S. How's the weather down in Naples? My Dad lives right down the road from you on Marco Island. He use to live in Bonita Springs. Wish I was there right now instead of being stuck here in KC with a little snow left on the ground from a freak late storm.
Do one more thing before you change your pump, check for a leak in the line from the tank to the pump. A very easy way to do this is to put some gas in a can and run a new fuel hose from the suction side of the pump (the inlet) into the can. Keep the can as even with the pump as possible (place it on the frame rail). Try starting the Jeep. If it starts and runs you have a fuel line leaking air.~~~ Checked the fuel going to the filter and some came out while cranking...not after the filter though. Changed the filter and still not enough fuel. I have a new fuel pup on order. I'll change that when it arrives and hopefully that will work! ~~~
Good Idea! That's how I originally started my CJ motor last Summer when I was assembling it but hadn't installed the tank or run the new fuel line yet.Do one more thing before you change your pump, check for a leak in the line from the tank to the pump. A very easy way to do this is to put some gas in a can and run a new fuel hose from the suction side of the pump (the inlet) into the can. Keep the can as even with the pump as possible (place it on the frame rail). Try starting the Jeep. If it starts and runs you have a fuel line leaking air.
Mr. Crabs is fixed!!! The new fuel pump got here and I installed it this morning and Mr. Crabs is starting better than ever! It must have been going bad and that was maybe why I had such hard starts??? Thanks again for everyone's help and for being understanding of my Limited knowledge. Maybe we can tackle my loose steering next...I'll have to post pics of the duct tape.
Jessica,Mr. Crabs is fixed!!! The new fuel pump got here and I installed it this morning and Mr. Crabs is starting better than ever! It must have been going bad and that was maybe why I had such hard starts??? Thanks again for everyone's help and for being understanding of my limited knowledge. Maybe we can tackle my loose steering next...I'll have to post pics of the duct tape.
There was a really cute crab sticker by the radio that he came with. It's a goofy smiling crab wearing a sailor hat. I can't figure out what it's from but I love it so I figured Mr. Crabs was a good name. Plus he is old and crabby! With the new gas pump he's pretty peppy though and starts better. Although (and probably because of the carb adjustments I tried) he's kind of lurching and jumpy in 1st gear.
