Looking for clarification on vacuum setup for MC2150 and Nutter Bypass
cuban11182
CORPUS CHRISTI
84 CJ7: 258, T5, Dana 300, Holley 390, Nutter Bypass.
For starters, I would suggest installing a valve cover breather and removing that pcv breather. These older engines seem to require a lot of venting due to worn out rings and valve seals. the rest looks pretty good but you could install a fuel return from the fuel filter. My $.02
Isn't that pink line the return to the tank?
I'll get a breather for the backside of the value cover through.
Sent from my SCH-I535 using Tapatalk
The fuel return line comes up from the drivers side and is a 1/4" steel tube. The charcoal cannister is a good thing to have but does have a constant vacumn drain. There is another cannister available that does not provide that constant drain and does not have a filter on the bottom, but requires a bit different vacumn line routing. I don't have the p/n with me at this time though.
Torx if you happen to find that info please let me know.
I don't know. I looked at my jeep and didn't see it.
No I'm fine with it. Time for us both to learn.
No thats not it it's mounted to the side of your intake below the carb.
Only vac I run. Is the line to the distributer like shown and the other is a manifold vac line straight to my egr. That's it. I ditched the charcoal can and without it the roll over valve doesn't work. I use a pcv breather
    Best for votes
    on specific items
