Moser 1 piece axle problems
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
I talked to Rob at Willys Works about your problem. He has seen this before. Is a slight variation in bearing race OD. But the most valuable thing he said was, "While a Dana 44 race is relatively loose in the bore, the AMC20 is supposed to be slightly tight requiring a tool to remove the race. If you can install, remove or turn the race in the hole the bearing is too loose." He said that Moser used to make their own bearings, but now use Timken bearings. He also noted that the Moser bearings were slightly SMALLER that the Timken version. I'm not so sure about that, Lumpy says that they still make their own bearings, I don't know.
