Suspension Old man emu YJ spring conversion
Another update.
So since I had to add a bolt for the new rear hanger (comes with the kit) I decided to fix the bad original ones. I drilled them all out welded in new grade 8 hardware. (Do not attempt this unless you can drill straight and weld hot) Also be willing to be careful around your other Jeep modifications. In my case my fuel pump for my EFI.
Paint as you go. Use lots of antiseez some people say use lock tight however I live in the north east rust is a natural lock tight.
A keen eye will notice one bolt sitting higher than the others. That's because my rear cross member is aftermarket and thicker. It came with a shim for the factory hanger so I reused it and made the middle bolt level with the cross member and the plate is now on the end bolt.
Always remember to tap your new bolt holes to remove slag or paint and for easier install.
(Yes I know I probably could have spent 25 minutes tapping the original messed up threads and using a big self tapping bolt for #3 but I'm picky)
The rest is fairly straightforward install just time consuming with pressing in the new polyurethane bushings and lining everything up.
Stay tuned for more updates as things progress. Unless I get off early tomorrow the next update will be Saturday.dd1172e705b2e6d50d9a8e97c690d4fc.webp021562573cc002538d2f452eca2482e9.webp767580250706c6f2483f78505c299131.webpe7adc67d385e5a59d7586c02ae11f24e.webpf0d21dbd110ced91c7cdff8f45cd410e.webp57f4b0c662eb3e5182c12b1caff7e7cc.webp7dea6b16b127dc0f16a6626c2e010162.webp0ac120d07fd3a83783e2ca00b8579ac7.webpf9328beff3c6d8e98a78c34e5262784a.webp
More pics from above
Make sure you have them pointed correctly (arrows for the unsure)166596b377a86086a45fa9cad51292ab.webp8f9b02e3697c44108ef644d649f1b053.webp032f1500a9603fe82be46e3bad74fa9e.webp7fb588c35d0be179d94c1d2566a4e087.webpf8e671914d592587d3ed2a2c13096fae.webpc383da2f5091ad8ccdcfc0316462b555.webp0648866ae4bfe8fd7d5d3fb01d1d687b.webp
Hey Manic, how was your experience with Rocky Road (service, correct parts, timing on shipping vs expectation)? I like their kit but haven't heard best things about their service. I tend to dismiss those reviews a little as people are way more likely to leave negative reviews, but it seemed to be pretty consistent feedback.
Thanks again for the help on my shocks question too!
Great service so far. I've called a few times over the months (bought back in July/August) obviously I'm just now doing the install.
Parts were all correct but for one exception I received 3 rears and only one front spring. A simple call and confirmation of part numbers and they processed a return. (Emailed me a shipping label). Once I shipped the wrong spring the new one was on its way to me.
The instructions are a touch out of date as the newer kits include new rear hangers (what I was working on yesterday) and the instructions mentioned simply reusing factory hangers with new bushings.
The times I needed to call (other than time difference) have been answered quickly and efficiently. Even after speaking with someone at one point in time I received a call from another representative since they noted a missed call from me.
In the very beginning before I even purchased their tech department was helpful in answering my questions about the kit and the suspected total amount of lift. I'm hoping for the lower end but we shall see.
They also asked me questions regarding gear, bumpers, top etc, etc to help me decide the best spring rate for my application.
Overall I'm very pleased with their kit so far and even more so with customer support.
The worst part of the whole thing thus far was the hit on my wallet as the kit with shipping to the east coast was almost $1,700 but I was mostly prepared for that after looking for a while.
Not much to update on today. More of the same as the other side. Difference being passenger side went a hell of a lot smoother. And if not for the extensive frame repair (rust was much worse than I thought) I would've started on the front before lunchtime.
However the rear is done with the exception of extending the brake line. I will do all of the brakes at one time.
I did however have a broken leaf spring in the passenger side.fc2d8f5fdece96968242e8ed018283e3.webp70307eb5f029e98e5ac654d5d1593d4b.webp7163265121a0d032c5d7525b316b96b9.webp841a2a3f47f60cbc9372fae5c140e638.webpa54eea657d17302eb5fa8bf3ae7edebb.webp1d211fc90726b7c6b38c23de25860752.webp
No updates today I didn't feel like going into the garage. Think I'm catching a cold or something. Also please excuse the clutter and mess in my garage it's been a long winter
Was all the new hardware included? I'm looking at starting with a new frame is why I ask.
Yes and no. It came with all the hardware for the suspension it self. (Shackles, springs, bushings and sleeves, etc) It didn't come with the bolts to mount the new spring hangers to the frame. (I think they want you to reuse your original) However both front and rear have additional mounting holes. Plus my bolts were rusty so I replaced them with new grade 8 hardware.
I did however pay extra for new u bolts front and rear and they come with new nuts and washers.
Now there’s a place for your anti seize, those bolts for the hangers. Rusty threads just waiting to happen on that frame. :)
I'm putting it on every bolt and the sleeves for the shackles
Project creep....
So I got some more done. The front although is more involved it's fairly straightforward. However I did have to remove my bumper. I didn't get as much done as I would have liked but I was on dad duty until after 1. But I did find time to do some shopping and well.... Now I have more project creep.
