Please help!!!! Distributor and ignition control module
khass0410
Pilot Point, TX.
75 Jeep CJ5, 4.2L Straight 6, Dana 44 & 30? T30 TC? 3 Speed,
I have a 1975 CJ5 w/ AMC 258 i6 / 4.2l motor, I have a 2 wire Delco Alternator I just went out and bought a new Coil, Solenoid, Distributor, & Ignition Control Module. I don't know how to wire the Distributor or the Ignition Control Module. Do I even need the Ignition Control Module????
On the ICM it has 4 wires that are in a pig tail Blue, Yellow, White, & Green I have no clue where these go?
On the distributor I have 2 wires from it to a little plug thingy. Anyways any help would be GREAT because this is all I have left to do being that I started on the harness 2 weeks ago and am just now getting to finish it up.
Thanks you guys :chug:
Can you take those parts back and get a HEI? Around a $100 or so. Faster starts etc.
The CDI was on 75s and a common upgrade years ago. I did it then.
If you bought a new distributor, does it have points? I'm pretty sure your 74 came with a points distributor. Points do not require the ignition module.
Absolutely the way to go it'll make you smile
I can do that but if I go hei do I need the ignition control module?
Is that one an alright one to get I'm going to try and
do all this today. Thanks again
Here is the one I went with. Got the wires from them too. They have a lot of good comments for support and service.
Heck they are probally are all made at the same plant anyway. :D
Jeep HEI's
1 week, 1 day, 4 hours, 43 minutes, 10 seconds
