Build Thread Starting from the frame 1977 CJ5
If you get a chance, could you measure the center to center distance between the rear x-member body mount and the intermediate mount? I thought I had measured it before I cut the rear x-member off but if I did I have no idea what I did with it. :confused:
Question, I don't need a sending unit with an electric fuel pump right?
Depends, if the pump has a built-in sender or not. Either way you need something to provide feedback to the fuel gauge.
Or you can keep track of how many miles you drive on a tank like me. Mine works but it’s not accurate.
Like I said earlier, Tim we are going to do this together. Both of us learning and succeeding. I just hope when we are both done there is some way we can meet up and see each others completed Jeeps.
You never know. I have a sister in Maryland, maybe someday we could work something out. I'll be retiring in a few years, and my goal is to have some jeep adventures in new places.
From the pix on the Pump Box, yes there is a Sending Unit Float.
Now, is it a "Low Pressure Pump" or a "High Pressure Pump" ?
Low psi for Carburetor
Hi psi for Fuel Injection
And if you are going to keep it a Carb Set up, you may also need a Fuel Filter with a Return Line.
I don't think that the original set up had a in tank pump.
You still have the mechanical fuel pump on the engine?
The in the tank pump would be a good upgrade if it matches your
Carb. Or if you plan on going to Fuel Injection. But that requires a ECM and other Electronics to work.
If you stay with a Carb,
and use this in tank pump,
Remove the old mechanical fuel pump and get a "Pump Blank" to cover the opening in the block.
They are available everywhere,
Even Fancy Aluminum ones.
