T-18 .... CJ5 .... Driveshaft?
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
In years past my first real jeep project was to install and adapt a V6 231 Buick, to a Ford T-18 , to a Dana 300 to a '80 CJ5 . For my purposes this was as close to a perfect jeep was is possible. But it could be said that I cheated a bit. Since the V6 is relatively short and the adaptor kit came with weld on motor mounts, I simply installed the 300 where it was in a stock application and attached the mounts where they needed to be.
While at Willys Works today Rob mentioned that he was surprised that I hadn't installed a T-18 in my CJ5 yet. As it turned out he has a proper CJ5 T-18 with a T-20 Transfer Case already on it that he's working on. Essentially he baited the hook and it's dangling right there in front of me.
Now for the tricky part. Rob said that the only problem is with the very short drive shaft. What? Then remembered how I cheated on the install of the '80. So, for you guys with a T-18 in a CJ5 . Tell me (and others) about how you dealt or deal with your drive shafts.
