TeamRush Ignition Upgrade
With the key in the run position, I'm getting 4.8 volts at the + terminal of the coil. Battery is showing 12.2 volts on my multimeter. So I guess I am not getting enough volts to the coil. Ideas?
Thanks Scott
I would start testing the continuity of the wires from there back. something is loose, worn, or a connection fried somewhere.
Do you have a wiring diagram for this beast?
Again, I would suspect if full power is not getting to the coil (as you state) that theres a small wiring problem somewhere to track down... Couple Cold :beer:'s and an afternoon and you should have it straightened out I would think (I've been there... :bang: )
~ JR
I thought I had a Chiltons manual, but it actually is a Haynes. I also splurged and got a service manual. I'm digging thru it now. Hopefully it's about to pay for itself.
Success. Turned out to be the Napa coil I put in about 1000 miles ago.
Scott
Back again. The new coil worked fine for about 100 miles, then same thing happened. Engine cut out. Got fuel, no spark. I put on a new rotor and distributor cap 100 miles ago, so I don' think its them. I checked continuity on all the wires and they appear to be good. I put on a new ignition module 100 miles ago. Decided I would do the stealth HEI mod instead of another new Duraspark mod. Done that, still no spark. I checked primary and secondary resistance on the e-coil and they appeared to be ok. Cleaned my coil connector and reseated it. Still no go. Checked my plug wires.
The team Rush mod, nutter bypass all worked good for about thousand miles, now the jeep has cut out twice in short order. It's been extremely hot here (100+) both times it cut out, but it did not appear to be running hot and temp gauge showed normal.
Any ideas?
Scott
A little more info. When I have the coil connector disconnected from the coil, voltage at the + terminal is the same as battery voltage. If I connect the coil connector, then voltage at the + terminal is 4.8v. Don't know what that means, but seems weird.
Thanks for the reply. Where is this resistor at?
Scott
You need to search for "jeephammer".
He is the god of ignitions, and IS teamrush
He has seen it ALL, and without a doubt can help you...
good luck
brian
good luck
brian
Here his Username is: TeamRush though he's not on (at least active) very often...
On Jeepforum He's known by: Jeephammer He's more active there...
I agree he can help you out with the particulars, If you have time to wait for a response.
If it was me, I'd start testing again. You should be able to track down the short / reason for loss of voltage. There's a loose ground, bad connector or wire etc, somewhere thats hindering you i think...
~ JR
Thanks. I've read a lot of his posts. Mr brother-in-law is gonna help this evening. He's pretty good with electrical stuff, so hopefully we'll git er done.
~ JR
I found him at jeepforum.com
and sent him a private message. He responded fast and was very helpful with my ignition issues...
Thanks for all the replies. It's running now and I must now admit that I am an idiot at times. My coil plug wire was loose at the distributor cap--doh! Brother-in-law figured it out very quickly. Oh well--wasn't the first and I'm sure won't be the last.
You say the Ford parts are a direct drop in? So you don't have to switch out the gear at the end of the distributor. This sounds nice and easy, My AMC 258 i6 / 4.2l gets poor mileage this looks like a good starting point. Thanks!
You say the Ford parts are a direct drop in? So you don't have to switch out the gear at the end of the distributor. This sounds nice and easy, My 4.2L gets poor mileage this looks like a good starting point. Thanks!
Yes, as long as long as your CJ was made after 1977 you have a Motorcraft Distributor. It's the same distributor found on fords.
Ok, I think I have read all the post, but did not see anything about the capability to work with an existing Howell Fuel Injection system for the i6.
I remember something about the tach feed and the howell. Is there anything needed besides the MSD box & coil, and adapter plug? I already did the cap, rotor, and wires and it made an improvement.
Thanks,
Joe Zeppe
:chug: BusaDave9, Just wanted to say thanks for this thread, I plan to upgrade my engine in the CJ7 soon and this is now on the must do list.
Dennis
$125.00
  62.5%
