TeamRush Ignition Upgrade
after reading ScottB's problem and other Team Rush upgrade articles, I am thinking about adding a ballast resistor. Good idea or waste?
Some coils need a ballast resistor.
It' the coil not the rest of the ignition that dictates if you need a ballast resistor.
The MSD blaster coils mentioned in this thread don't need a ballast resistor. If you get a different coil read the instructions and recommendations.
Are you getting a MSD ignition module?
Yeah, I am planning on getting the 6201 like you recommended. I don't think I need the waterproof version since I don't plan to submarine. Torxhead...I didn't do the above, I copied it from another Team Rush article.
good write up. i did this to my 258 and well worth it. i went with a msd blaster 3 coil and a streetfire (msd econo brand) box. the strretfire has two dials on this side to adjust the rev limiter.
Where did you find the MSD distributor cap for the AMC 258 i6 / 4.2l (or the Ford 300 for that matter). I can't seem to find it.
Also, first post. Seems like a great forum so far!
Hey Dave, why does the red wire from the A6 have to hook to the old coil cap if you won't be using that anymore. I think I am finally getting it. So the A6 pretty much cuts out the old ignition module on the drivers side under the overflow tank? But, you recommend keeping things and the old coil on hand in case the A6 goes out on the trail than it's a simple reconnect the old coil adaptor and it should run as normal.
I have bought the equipment team rush recommends but I am not sure about the wiring of the starter solenoid. I am using the painless harness and I have to run a jumper wire from the s terminal on the solenoid to the white wire on the old duraspark ignition module How does the starter solenoid wire into this set up using team rush upgrade? thanks
Dave, did you replace both timing advance springs or just one and leave one of the originals? The order came with two, but I know they can be different sizes depending on how you want the advance to take place.
I replaced both of mine. :chug:
I just finished up but would like someone (BusaDave9 if available) to check my work before I put power to it. Heavy Red and Black to battery (pic 1) Orange and Black to Coil (pic 2) Small Red to old red on old Coil adaptor (pic 3) - I plan to get a better connection on this...it's a little weak right now. Last purple and orange to distributor module (pic 4) White and gray not used at this time and I just tucked it away. (pic 5)
Looks good. Sounds like you are ready to power it up.
You can cut the old coil cap completely off if you want. Then connect the red wire from the MSD ignition module to the red wire that used to go to the coil connector. But the way you have it should work. Cutting those wires means you will need to either get crimp-on connectors or solder the wires.
Yeah, I plan to on making it a direct connection or at least get a better hook up. I thought I would leave it on in case the Jeep Gods are not pleased with me and the A6 goes belly up I can reconnect the old set up. Thanks again Dave for all your info and guidance.
Well, it cranked right up and sounds nice and smooth. I haven't started to readjust the timing yet as when I went to switch it off it continued to run. I had to disconnect the neg lead to the A6 to kill it. Did I miss something? I will re-read this thread.
Here is another pic of that whole set up. The old coil connector had a red wire and green wire for the pos and neg. It also had a capped off red/white wire you can see. I connected the small red wire to the old cap using a split wire that had the right connector, you can see the one split I have taped off and the other connects to the old positive side of the old coil adaptor. I was reading about attaching a diode to fix the problem but there are not any good pics as to where or what wire from the alternator this is done. Pic 2 is the back of the alternator and pic 3 is where everything ties in together on the fender. Does the diode install on the red/white wire in pic #3 or ???.
