Build Thread The $120 Jeep CJ7 build thread
Looking good, cutting and drilling frames are nerve racking things to do so don’t worry about that, I have had quit a few 1/2 inch drill bits catch and pull the drill right out of my hand as well so don’t think you are weak for that
Weaker than I used to be... I was always the strongest guy in my unit except for the first few years when I was young and scrawny. Something too heavy, go get Sgt C.
Sweet
Yeah, that swap is a no brainer......
Sent from my iPhone using a cold one. I mean Tapatalk.
The 727 is the big brother of the 904/999 it was used for all big blocks and Cummins diesels, check to make sure there isn’t an output shaft bearing retainer snap ring on the 727 tail housing, I know it’s there on the 2wd Transmission . The cog is Park, when you shift into park it pulls the park rod that is attached to the valve body forward and that makes the lever engage the cog
I think I remember you saying that the Mopar 360 had the 727/NP205 combo, it looks like you have a huge bolt or nut holding the input gear of the Transfer Case to the output shaft of the 727 Transmission . I think what you are going to need is the 23 spline output shaft and tail housing from a 727 that either had a NP208 or Dana 300 , I have no idea if the 904/999 tailhousing or output shaft will interchange with a 727 or not
I think I remember you saying that the Mopar 360 had the 727/NP205 combo, it looks like you have a huge bolt or nut holding the input gear of the transfercase to the output shaft of the 727 trans. I think what you are going to need is the 23 spline output shaft and tail housing from a 727 that either had a NP208 or D300, I have no idea if the 904/999 tailhousing or output shaft will interchange with a 727 or not
The running combo out of the '79 CJ5 , was the 360, 727 and a Dana 20 .
The '80 CJ7 had a AMC 258 i6 / 4.2l , (with a window in the #2 rod area) 999, and Dana 30 .
The 727 is the big brother of the 904/999 it was used for all big blocks and Cummins diesels, check to make sure there isn’t an output shaft bearing retainer snap ring on the 727 tail housing, I know it’s there on the 2wd trans. The cog is Park, when you shift into park it pulls the park rod that is attached to the valve body forward and that makes the lever engage the cog
My neighbor was over helping one day a while back and was asking about the Transmission . He was moving the shift lever back and forth on it, and now it won't move. I did drain most of the fluid out so it wouldn't spill everywhere, if that matters.
My neighbor was over helping one day a while back and was asking about the trans. He was moving the shift lever back and forth on it, and now it won't move. I did drain most of the fluid out so it wouldn't spill everywhere, if that matters.
I would say you either have a shuttle valve in the valve body stuck or your park rod is jammed against something
Dang that’s some serious metal on the back end love it
$125.00
  62.5%
