Build Thread The '80 FrankenJeep frame off reassembly
- Media
- 5
- Solutions
- 1
- Roanoke, Va
- '80 CJ-7, AMC 304, T177, Dana 300, Widetrack axles (D30 & AMC20) w/ 3.73 gearing, MSD ignition,
I o got the skid plate issue fixed. Well, actually circumvented. I've never liked CJ skid plates - every Jeep I've ever had they were a PITA. This one was on the Jeep when I got it, and drove it, so I know it fit once upon a time. I did swap frames, but the Jeep is an 80' and the donor frame was set up got narrow track axles so I assumed it would be close enough. Anyway, once I got the engine/Transmission back in, the Transmission mount was about a half inch too far forward by a half inch or so. None of the several combinations of skid plate mounting holes would line up, so I welded up all the holes and slots for mounting to the frame, marked and drilled new holes to maximize the forward mounting position. It was still too far rearward, so I welded up the Transmission mounting holes and drill ed new ones. So far so good. Went to bolt up the Transfer Case , and it stopped 3/16" short. Dammit, man. This is where it was bumping the skid plate:
So to fix it, I cut out the surface it was whacking into, cut an extra inch out, and then welded the inclined surface to the forward side of huge cutout, back filling with similar gauge steel.
Not sure where the difference in figment came from - the motor mounts went back just they came off, same engine, same Transmission , same Transfer Case ....... Whatever, it's in now and seems to be happy. Rear drive shaft went back in nicely, but in my wonderfully clever method of organization skills, I have yet to locate the front drive shaft. Farts. I'll keep digging.
New Warn hubs go on tomorrow. I had thought about cleaning up the old hubs and reusing them, but I was unable to get the outer portion apart for cleaning and reprinting. Warn couldn't even tell me. They are the old manual / automatic hubs. Gonna clear them outta here since I went ahead and got the new ones.
More later
More later
