Build Thread The '80 FrankenJeep frame off reassembly
'Bout time for another picture of that rolling chassis! :)
Looking good!
Looking Good! :banana: Nice Bends! :banana: What did you use for brake lines? I still need to do those on mine. :chug:
You are soooooooooooooooo lucky. I had to cut my body mounts off, cut my shackles off, cut my springs off, there are so many body bolts that I will have to drill out.......................you get the idea. Some of this is why I went all in to completely rebuild my Jeep.
Shum8, crimped connections are not good for a CJ, You might want to solder that and run the ground wire as close to the battery ground as you can for a better connection. The CJ fuel gauge system is not all that great. A little o-ring lubricant or grease can help also.
I think one reason I haven't had much trouble yet is the PO swapped in a Wrangler tub, and used anti-seize everywhere. Speaking of which, anybody know why I can just look at the can of anti-seize and I find it all over me???
Yeah, I'll be sticking ground buses here and there - just haven't wired the rear bus up yet.
Yeah, I ran a rear ground wire for the tailights and gas sending unit thru the rear harness. Now the lights are a lot brighter. Can't help you with the anti sieze issue.
May have something to do with operator error...... [emoji849]
Did some pokin around this morning - don't have rust in the tank [emoji106][emoji106]. It's old fuel. Stuck a long screwdriver in the tank and lightly drug it across the bottom they the "rust". It piled up on the end of the blade.....Nice - that can be cleaned out relatively easy - compared to rust, anyway.
I hope you didn't jinx yourself on the bolts now. :D That is crazy none broke. First bolt I touched on my 82 snapped right off.
I guess since he had swapped tubs, he broke em all....... I missed out on all the fun. [emoji41]
$150.00
  75.0%
