Build Thread The '80 FrankenJeep frame off reassembly
So - It appears I made a bad assumption..... ok, another bad assumption. This isn't my first by a long shot. I got the driver's side seat riser modded to move the seat out and level it up..... then decided I liked the CJ risers better so I tweaked ahead and tweaked them to work. Now the driver's chair sit level and clears the door by about 1/4 inch...... the passenger side was on a nice looking forward folder, so I grabbed the spare cruddy one to mid.... so I took my measurements from seat to door, cut, welded, ground, and drilled............ then began the swap. My first indication something had gone wrong was the slider mounting holes were different on the modded riser. No biggie - I remember where I put the drill...... set the modded riser in the tub to verify dims, and that was my first WTF moment. I was off by like almost two inches. I'm not the sharpest tool in the shed, but I'm not the dullest, either. The math was good. Got to looking, and noticed the two risers are actually made differently. I guess the one under the seat was a Wrangler riser...... either way, I have more work to do today. Once I get that fixed, I just need to get the Transmission cover plate with the Madonna boots installed and she'll be ready for inspection....... I'm so close to driving it I can taste it.
Sent from my cool, low humidity, air conditioned basement using Tapatalk
Man that will be a great day
Copy that, Ghostrider!!
I gotta hurry up and install the cover plate and shifter boots an get em scrunched down....... every time I look at em right now they make me think of Madonna.......
Sent telepathetically using Tapatalk
Lol
Get it done before the wife wakes up
Shum8 do you think you have enough clearance around your Transmission shifter to tunnel? They do vibrate around a bit
Shum8 do you think you have enough clearance around your trans shifter to tunnel? They do vibrate around a bit
I thought about that when I stuck it in there - there more clearance with the boot, so if it bumps the Transmission I’ll just open it up a bit with the die grinder. We’ll see [emoji6]
Pretty interesting
Pretty interesting
I was thinking a man of leisure or time on his hands ?
Empty nester?
Maybe has run out of ideas on what to do next with the jeep ?
HAHAHA - Uh, no. Empty nester, yes. But the only thing before trying to get it inspected is the seatbelts. It been - going to rain thru mid next week or whenever the dang hurricane gets done with us, and the top is off. I’m stalling........
Leak check time lol
Oooh - I’ll work that in after the seatbelts. Good call.
Gonna try to get the half cab on tonight when I get home. The rain is really coming. And the Scrambler parks outside now that we have the 3a. [emoji29]
Are you getting slammed now? I heard parts of DC looked like Venice. Thought you might be getting a head start on being soggy....
$150.00
  75.0%
