Build Thread The '80 FrankenJeep frame off reassembly
Nice job! I have thought about adding a sub in the Scrambler. The sound is just :dung: in the CJs
This little sub works great - got it used on ebay
Sent from right here.......
Well, I got all the top hardware together, cleaned it up and repainted, the top is awaiting a nice warm day when I have the time to remove the hard top, and then it hit me. The YJ uses a tailgate bar to retain the rear window. Dug around and found the bar. Opened the bottom drawer of the tool box, end there were the bar retainers..... I do believe I have ALL the parts..... Now for that warm day .......
What type of temps are you having up there ? Just about perfect here last few days. Sunny low humidity & upper 60s
Last several days we’ve been in the upper 50’s and frosty mornings..... but upper 60’s and lower 70’s inbound starting tomorrow. But being a new top, I’m gonna need some sun and a little warmth for the initial install. That sucker’s gonna be tight I bet
yea the weather is going to warn up here also, warm coming up out of the Gulf of Mexico and chance of storms on Sunday like last weekend
I plan on running it a couple weeks and reporting back. It’s raining today - so the rain eval will be easy LOL. I wanna see what it does at highway speeds.......
As for my tub - I have no idea what year it is. It was already transplanted on when I bought the Jeep. But you are correct - I’ve never seen an antenna mount that far rearward either. Weld the holes up and redrill??
That’s why I scrounged up a set of YJ hardware. Got it cheap several years ago. Bolted right up. You will have to drill a couple holes along the sides of the windshield frame, and possibly a few along the tub for the side rails...... to update to a newer top I’d do it.
So how is your top or hardware different from other people’s tops ? Wondering why you need a fix and other’s are not riding around with holes ?
Beats me. The YJ hardware I’m using appears to be good - no worn joints or pivots. The spreaders in question do, when in place, are slightly “over extended”, but I just figured that was by design so they stayed in place. I was going to flip em over to put the knuckle pointing down rather than up, but pretty much immediately realized that would have the fold pointing up rather than down - no bueno. This was just a quick and easy fix till I figure out what’s going on. If all other YJ tips do this there should be a lot of holes running around LOL. Other than this, the top is great. And like I said - I think this is a hardware issue, not a top issue.
I am trying to remember the soft top I had on my old 95 YJ. And when the top was on tight, the canvas did not rest against the spreaders. But I cannot remember if there was a built is protector for it.
It may be the way the top is sewn..
Seems like more of a hardware problem otherwise the tops would be returned
My first corrective action I think will be to reduce the amount of over centering..... see if that helps. But we’re expecting a small monsoon tonight - so I’ll take a look at it in the next couple days. I am going to post up a review of the top in a couple days - tonight will be a good eval if potential leaks......
Thread posting test.......
Well, looks like it went, but it’s awaiting approval.
You done anything on your Jeep lately?
