What happened ? Junior looks pretty clean in that picture
Lmao he was not, I had mud in his hair arms back of his neck all over his clothes, I decided to stop and give the winch a try instead of filling the Jeep completely full of mud
You’re going to need a bearing clamp in the snap ring grooves with strong back and threaded studs. Check out Gearbox Videos on YouTube Paul does a great rebuild on the T176.
I struggled for another hour today then gave up and took it to a Jeep shop relatively nearby to have them do it. Instead I replaced my clutch plates and got it cleaned up to reinstall the tranny when I get it back.
Sent from my SM-A405FN using Tapatalk
Removed my Transfer Case from the Scrambler. So it will be ready to yank the motor out. Decent weather so I had no excuse. Now to take the head off of the motor being swapped in.
Always interesting when you are under the Jeep and find little bits. I wonder if the needle bearing is from an old u-joint or one currently on the Jeep. Hmmmmm
You must login or register to view hidden content on this page.
Sent from my SM-G950U using Tapatalk
Today fresh oil change, new anti rain equipment and ws able to fit her in the garage without airing down a1f903ebc9297600253d3c3366a0455f.webp d9edf3a3a41ff9929a05a17d1c651f05.webp 5aebe653c2887c3507137d448d02b896.webp
Nice score [emoji106][emoji106]!!
Sent via Tapatalk from behind a nice, bbl aged stout. Forgive my spelling LOL
New Title, New Plates, and Insurance! The important stuff!
Finished my tranny rebuild and got my 81 back on the road, what an adventure that was
Syphoned gas because I have a leak in my tank... 7c9e22bfc2b9d1670a1c4688be46416a.webp
Finally got around to taking the garage back over so I can fit my 76 back in. This is after repairing the rear end of my frame where the bottom of the frame peeled away at the spring mount. Welded in a new rear crossmember from MORE instead of the PO's craptastic angle iron. Also got working on the 351w again. Haven't been on in a while so I figured I'd post everything up! 1a1b7e706b0b05815429880766ae2c69.webp 57e7ba9da14d03127779af0ae49b6c06.webp 475b03082c61cf883311014b2a6128e1.webp ada02a02c137efa1dd9e6c51bc480fa2.webp ea75e315f1ebf498e26acef0e86329f4.webp
Sent via Google translate using braille through Tapatalk
Replaced all the bushings in the stabilizer bar. Ten bushing in all, bushings for the connecting links are two piece, Used prothane bushings so they should last a long time.
Pretty easy job, of course there are always a couple of bolts that are either rusted or hard to get a wrench on.
Took it for a little test drive and it drove well.
Next on the docket will be to replace the spring bushings.
Read an article a out it. The write up had a couple things inaccurate, but whatever. This is in a magazine local to my town. The extra photos were a couple of pics the photographer sent me that did not make the article.
VERY COOL, Sir!!!!
Sent from just this side of consciousness- Time to hit the rack.
Well, I feel like an idiot! After taking my steering stabilizer off and replacing the bushings yesterday I got to looking at it today and it just didn't look "right".
I searched my FSM and Haynes book and did a lot of searching on line for a good pic of one installed on a Jeep. Both of my manuals only showed the stabilizer bar by itself and I never could find a good pic on line of one.
So.............I pulled the Jeep in the basement, took it back off and flipped it over. It went on pretty easy but after I got it all bolted up I noticed it was rubbing the tie rod. That can't be right, so..............I took it off again and reinstalled it like I had it to begin with.
I'm getting pretty good at it, only took about an hour to change it the last time. Practice makes perfect!!!!!
Anyway, I feel confident it is on correctly. [this time] I should of taken a pic or paid closer attention while taking it off the first time.
On another note, UPS delivered my Smittybilt security console today. I ordered one over a week ago and found out it was back ordered and wouldn't ship out till the end of the month. After a little more searching I found the same one from another vendor that was in stock and $20 cheaper. It arrived in two days!!
Took me about an hour to get it installed, and I am very pleased with the quality and how it looks.
$150.00
  75.0%
