I pondered it a bit and then called mriplaybass and we talked it out and he suggested I "might" try ported vacuum instead of manifold vacuum due to what it does for timing.
I tried it and it idled like a sewing machine for 20mins. You lose some low end throttle response but it taught me something.
I may go back to manifold and back off the timing 3-5 degrees and see what happens. See if it get idle and throttle.
It came from the factory with ported vac and I tend to think the engineers know what they are doing.
What did I do today? I got home from work and going to re install my main shaft on my NV4500 and discovered that the PO had disassembled my Transmission further than I thought, so now I am going to have to order new countershaft bearings so I can assemble my trans :( good news is I toke the countershaft out so I can throughly clean the case inside and out
Wheeled it like it has never been wheeled at Rausch Creek in PA. Had a great time. I was leading a group on some Green/Blue trails and took myself on some black obstacles to test myself and my somewhat freshly rebuilt Scrambler. It did great. I had a blast.
Maybe not today, but this is the first time I have had a chance to post since we were in Colorado! :)
On our way back from the 6th annual Jeep trip in Colorado Monday, we blew a tire on the trailer. Turns out the tire blew because the brake drum shattered and tore up the side wall, but that's another story.
How is this a "What did you do with your Jeep today" story?
Instead of having to use a tire iron, which mounts under trucks hood, and gets very hot! I merely got out the impact gun, climbed up on the trailer and started the Jeep, switched on the on board air, and the tire was off and the spare put on in about 3 minutes! :D
Love that OBA!!!
Neuner - Great name for a CJ5 , I'm not so sure about a CJ7 .... :) Made me smile, thanks.
Thanks guys. It's just one of those things that happens on the trails sometimes. I ordered some new mirrors and I think I'll just need to readjust the windshield. I don't think it's bent.
It looks like I'll be able to take my spare tire carrier off and stick it in the shop press to straighten it.
Drove down to the pier in the CJ to pick up some Lobstah! :chug:
One of the reasons I miss living near Woostah and Gawdnah. :)
Mstar, that is a great looking CJ, Do you know who made those wheels? They look like a set of Ansens that were made many years ago.
O.E.M. Renagade II American racing 15x7 D-slots AFAIK.
Relocated my CB antenna upward. Part of my quest for better range. :)
Bill, FWIW. I get the best range from my CB using a 102" SS 'whip' ant.
I keep it 'folded' over on the trail.
May I ask what antanna you're using?
