hey gert whats dragging from your front axle in your you tube video?
anybody know if IOPort is still here?
He last hit the site 18 June 2018. Don’t know where he’s been..
Sent from the couch using Tapatalk
That’s my unfinished parking brake install, I went with a disc on the back of my Transfer Case and the cable is not long enough to get to the caliper so one of today’s projects if I can get to it is to move it to the parking brake lever and use a rod to get to the caliper
Is that called a “Stomper 4x4”? Or something like that? I had a couple when I was much younger. One was a 70s Blazer.
That’s what it is - they made a couple varieties of Jeeps, one being a Scrambler IIRC....
Lol do the gauges work?
Oh, hell no - it’s a CJ. But the headlights work [emoji106]
The set I bought many years ago worked right out the package
Well, considering the fact that I have no idea whether or not my mirrors are OEM or not - that’s probably where my issues came from
Sent from outside using Tapatalk...... Heck yeah it’s like Springtime out here [emoji106]
Looks good.
I noticed the push plate are you currently using your 3a to plow the driveway?
100 bonus points for a painted spare wheel
500 bonus points to pinstripe all 5. :chug:
Thanks. It had a plow, but I did not take it when we bought the 3a. I have nowhere to store it here in my garage.
And yes, I need to get that spare painted. I plan on getting 5 new tires soon. These are pretty dry rotted.
Are you going to try and find the old school type of tires ?
Installed a new fuel pump on my '84 and got it running again after sitting for a while because it wouldn't pass the smog test. I still need to pull the carb and put a rebuild kit in it and check the EGR to see if it's working right. Then I hope it will pass so I can start driving it again.
I got a lot of help by replacing all of those vacuum lines. I had an O2 sensor go bad and that did cause a problem. I wish I had seen what this guy wrote:The Three Major Players. I can now adapt a digitial voltmeter to test its operation. I always the change gas filler cap every few years as the smog man charges a fortune to replace it since it has to be tested on all my cars.
