Finally got around to putting in my new vapor canister. I am convinced the old one was original. I noticed any immediate reduction in fuel smell with the engine running.
Ignore the wiring rat's nest, that's what I am doing until I get around to replacing the complete harness.
Sent from my ALE-L21 using Tapatalk
What year make and model did you use to get that canister?
Sent from the paycheck source using Tapatalk
I actually did a whole bunch of research online. They don't make CJ7 vapor canisters anymore although some oem ones are available from junkyards. I ended up getting the dimensions of my oem canister and calling Rock Auto and ordering one based off dimensions. The one I got is from Standard and only has three ports instead of four. I just eliminated the hose from the PVC valve to the canister.
Bought the paint....if the weather co-operates...I’ll be getting it all painted..three coats of base...three coats of clear...quite excited to be at this stage..been a while coming...
We’re almost as impatient as you are.
Ok, maybe not that close, BUT HURRY UP ALREADY....
Sent via my universal translator
Got the jungle gym as done as I’m going to do for now
Sent from the road using Tapatalk
How about a couple of pictures of where you have the new back bar attached ?
I used the factory mounting holes, the supplied plates are 4 hole plates versus the factory 2 hole, also the factory mounting holes are offset for whatever reason so one bar is at the front of the plate the other is at the back of the plate, I do plan to frame tie these rear bars and use all 4 holes
Sent from my kitchen using Tapatalk
Thanks gert...I’m liking the colour...been putting off the electrics..guess I’m into it now...lol
I am thinking yours is in need of an upgrade in color to a nice camo color of some type. :) Those colors really look sharp on those older jeeps
Nope. Not gonna fake it. Mine was a civilian Jeep. It will stay it’s original color.
I think you are only faking it if you applied emblems and insignias or 4 stars like Patton or MacArthur. It's yours, that's fine with what you have.
Finally got around to putting on the cover on my rear differential. The new one has a drain plug so I won't have to pull the cover to change the oil.
    Best for votes
    on specific items
