- Media
- 5
- Solutions
- 1
- Roanoke, Va
- '80 CJ-7, AMC 304, T177, Dana 300, Widetrack axles (D30 & AMC20) w/ 3.73 gearing, MSD ignition,
Dont forget to modify that dizzy to get more mechanical advance if you had the ecu controlled dizzy and carb. Those model had very little advance and without a working ecu your engine power will suffer greatly.Cleaned up some more wires to nowhere in the engine bay. Moved the choke wire to an actual fused ignition on circuit and adjusted it- made it run much better.
Decided to do the Nutter bypass while the loom was open. Got everything tidied back up and eliminated the wire nuts at the alternator.
Ordered a remanufactured dizzy from Napa it’s about the same price as a new vacuum can.
Oh wow, those last couple of mud holes were scary looking lol.Oh man I cannot tell you how awesome my Goodyear duratracs and Eaton true tracks are, I idled true most of the trail only using the gas pedal for a few deep holes..... when I started this trail I had some pretty good pucker factor going on whether or not I would get stuck and have to winch out now I see I have a very capable Jeep
https://youtu.be/MHEvbqxsh_8
Yep, i'd say you have a very capable Jeep!!
Sent from my SM-G970U using Tapatalk
Found the lowest part of my Jeep it’s the rear dif lol.
Yes - yes you did. Isn’t it more difficult to maneuver the mud holes with the hood up??? Or did you break something else??
Sent from work......... yay.
Pulled my transmission and then struggled with pulling the rear bearing until the shop closed and kicked me out until tomorrow. Now I have all night to game in my head how to get the bearing out.![]()
Sent from my SM-A405FN using Tapatalk
