As in vendor provided installed one ? Reason I ask is because I got my glass replaced over 25 years ago and actually provided one. Picked up my jeep and it was still laying on the seat. Asked why and was told me they had something better. First rain it leaked like a sieve. Brought it back and still leaked. Finally sealed it myself.
Yes. It came with the windshield.
Bad deal on yours bu so long as it’s fixed.
Washed it again and ran it most of the day (well wife did). Popped on this fire extinguisher tonight.
Flushed the frame in preparation for shooting it with Eastwood here pretty soon
Based on the amount of sand, she must have seen some beach time with one of the POs at some point
Between that and the sticks, rocks and wasp nests, I'll probably pick up several miles to the gallon now
Cleaned the 4.0 block. That was a mess. I ended up covered in oil. Now to paint it blue
Also finished cutting of the snow plow structure from the 3a. It has the ground clearance now. And took it for a little spin in the neighborhood.
Tried to change the gas tank
Sent from my SM-G950U using Tapatalk
Finally got around to installing the headlight relay kit, I bought a year ago. Damn virus lockdown, I can't drive around to check it out tonight. Oh well something to look forward to when the lockdown is over. Everybody be safe!
Changed the oil and drive around on a few errands.
Still need to give it a good wash.
Sent from my LM-Q720 using Tapatalk
Got my new top today...... went ahead and bit the bullet
Sent from right here.......
Yup - was gonna just grab a Smittybilt replacement top.... Just refurbed a set of YJ hardware so the replacement skin would work nicely. Was never super fond of the black denim fabric, but figured what the heck. Then ran across the special edition top they put together for their 30th anniversary.... it fits a YJ but looks like the newer black fabric tops. Got here this afternoon so I’m excited to catch a warm day to install it [emoji16]
Finished my wiring harness install. Had a couple hiccups and it took way longer than two days but I am finished at last!
Sent from my SM-A405FN using Tapatalk
Glad it worked out. They're making mine right now. Should get it next week some time.
Sent via Google translate using braille through Tapatalk
Dropped mine, too...replacing with a tub mount for an upcoming axle swap/stretch
Sniper on the way...should be able to get going on that by the weekend
Loved my sniper while I had it. Best thing I ever did. Are you doing the 2bbl or the 4? I had to do 2 minor things after installing mine. Added a piece to the throttle linkage to eliminate the bad throttle tip in, and I had the notorious high idle so I had to do the trick of covering the iac port, set the idle, then reboot the module. But super easy and well worth the modifications
Have a pic of what you did to the throttle linkage?
I took some close ups. But cannot find them at the moment. I will post when I do. But basically, there is a hole where you bolt the throttle cable to the rotating arm on the unit. That angle is not good enough to overcome the suction of the butterfly valves in the unit. So I took a scrap piece of flat metal and cut it and drilled to holes 1/2 inch apart. Bolted it using the lower hole to the rotating arm on the sniper. Then attached the accelerator cable to the upper hole. So it raised the mounting point 1/2 inch. Just enough leverage to make the tip in go away. Holley sells an extension for about $11. They also sell a progressive linkage so that only one set of valves open at first. This is the best option. For fuel efficiency. But the way I did it was free.
Go to the Sniper facebook page and you will see many posts about throttle tip in.
I'm going to start working on my Jeep again in earnest now that my money issues are about to disappear...
Hello Dear,
I Mrs Julian Wayne,I have been touched by God to donate my inheritance to you for the good-work of humanity rather than allow greedy relatives to use it ungodly way. Contact my lawyer Mrs Elisa Foster via email;{mrselisafosterfirm@yahoo.com}
Inform him you are the recipient i have bequeathed $58,000,000.00 (Fifty Eight Million USD) to you ref number; JWILL/46534-827. I have also notified him that I am bequeathing that amount to you by my personal decision I will appreciate your utmost confidentiality in this matter until funds is claimed by you.
Good Luck,
Mrs Julian Wayne.
