I did something similar but i lose too much throttle. I’m going to cut and shorten the cable mount. No choice.
Loved my sniper while I had it. Best thing I ever did. Are you doing the 2bbl or the 4? I had to do 2 minor things after installing mine. Added a piece to the throttle linkage to eliminate the bad throttle tip in, and I had the notorious high idle so I had to do the trick of covering the iac port, set the idle, then reboot the module. But super easy and well worth the modifications
The two...going in place of the MC2100 that replaced the original Carter
Your praise of it helped sell me on it. If you're willing, I might have to pick your brain as I go through the install and setup
Looking forward to the benefits of it for sure
He’s a great resource, and myself and bass have snipers as well.
Of course.
By the way, what fuel pump are you going with? Internal or external? I went with the external that came with the master kit. I mounted it on the crossmember right in front of the tank, despite all of the warnings. Worked just fine. And was well protected.
What I loved about the sniper vs my carb was how I would be off camber and it would not stall out. And I could start it up off camber without having to level the Jeep out first.
Had to take her out for a drive. :D
Took the wife and pup for a little ride to one of our parks. We got out to take a little walk and the wife noticed my Jeep with the flag in the foreground.
Old Glory long may she wave!!
Doesn't get any more American than that.
I got this boss block off plate for the Sniper install...
Have to say, based on the attention to detail...whoever did the engraving sure knows CJs...
Even got the oil slick underneath LOL!
Pretty cool. Where did you get that ?
Well not today, Monday & Tuesday removed the hood grill and fenders first. Then remove all the pieces off those parts and striped the engine of all accessories. Only a couple of bolts holding the engine in now. Engine Transmission & Transfer Case all coming out next week. Then it will be time to clean the grease and oil out of the engine compartment
Got the the new soft top installed yesterday.... fits nicely, and (I think) it looks great.
Could have done without the tag, but it’s such a nice top I can live with it
Sent from right here.......
Thanky! It went on MUCH easier than I was expecting.... almost like it was supposed to LOL
Any way to remove it without making it look like :dung:?
Sent via Google translate using braille through Tapatalk
The top? Or the hardware?
