I like the Pontiac 455 in the 89 YJ 1cd275bf67d88ee47e5fd05b38100402.webp e69bce29c0737a7bb8b167f6a5232a9a.webp 8e4d9139dc1d156b72bb289d611612cd.webp 7880543f09a00ed3f5edfaca25c1487b.webp 6f4f8b4e60fb7d4f74c5e00e1ef0536a.webp 352b33d254a98e0450a2b99dc2700669.webp
I guess if I had wheelie bars in the back. And got rid of the AMC rear axle
The 20 is cool as long as you get rid of the two piece... ;) The ring and pinions are stronger than a 44...
Done correctly it's stronger than a Ford 9"
And the one with a wheelie bar is TJ stock would have been a Dana 35 trash
Moser about 30 years ago.
Just buying more parts, decided against Dana 35 as I don't believe it will hold up long term to the the Chevy drivetrain so sourced a nice Chevy 10 bold from a 4x4 ZR2 S10, 8.5", heavy axles Limited slip 3:73's drum brake version, I know a lot of them had disk but wanted to keep the rear drums, plenty for a Jeep with front disc.
Bought a nice aluminum billet Edelbrock air cleaner for the 350 to go with the billet valve covers.
Only slightly upgrading the front axle assy, going to use a TJ Dana 30 with 3:73's cutting and grinding off spring perches. It at least eliminates the 3 axle dilemma solenoid etc.
And weld the tubes to the pumpkin. I've seen them twist. I have one in my junk pile.
To much pressure on the skinny pedal ?
The AMC20 has a reputation for twisting tubes, along with a couple others, either from hard launches but mostly from slip and grap, especially in the midwest where more mudding and dirt racing was/is done especially with the older CJ's, and as old as they are you never know how the PO treated her if the original owner. Besure and keep it cool when welding the tubes, do short weld sections cooling inbetween, as tubes can warp and often transfer welding heat to the seal areas and end up leaking diff fluid shortly after, why most welding done on tubes during rebuild and replacement of seals etc.
https%3A//i.ibb.co/2SfdtYb/IMG-20230902-183132779-HDR-edited.jpg[/img]'] IMG-20230902-183132779-HDR-edited.webp New tires and wheels today.
https%3A//i.ibb.co/56MmSDW/IMG-20230902-183146845-HDR-edited.jpg[/img]'] IMG-20230902-183146845-HDR-edited.webp
Turned it around in the garage so I can finally get started on dropping the fuel tank and get down to some serios rear end metal work
Sent from my SM-A528B using Tapatalk
Looked at it and said nope not in this 100⁰+ heat with humidity
scout 1067: Turned it around in the garage so I can finally get started on dropping the fuel tank and get down to some serious rear end metal work
Are you experimenting with the new Titanium ... toy...🤣🤣🤣
No, but tje rear end rusted by the tailgate hinge mounts so I have to cut out the rot and replace the entire rear crossmember. While I am at it I am also going to put in new aluminum brake lines
    Best for votes
    on specific items
