Wiring issues - help needed!
4x4Dad
- Yorba Linda, CA
- Big Jeep - '88 Grand Wagoneer: AMC 360, 6-7" of lift, TF727, NP242, Howell FI, 3.31 gears, Dana 44's front and rear, 32" BFGs, ...
Little Jeep - rescued/resurrected '51 CJ3A with a Ford V8, CJ2A window, 2.5" Rancho lift, 31" Super Swampers, CJ7 Dana 30 front axle, ...
I've got a weird combo of vehicles/parts that I'm trying to merge into one, so please bear with me.
1. My rig has a Ford 260 V8 engine, a universal 12 circuit wiring harness, and a Signal Stat 900 turn signal device (the one with seven wires).
2. I'm using the stock CJ3a headlight switch with the two settings/options, parking lights or all.
3. I'm using a CJ5 dual filament parking light from Omix-Ada and Walck's Naco Standard CJ2a tail lights (the one with a red wire and a black wire out the back).
I'm trying to figure out how to have the parking lights go on with the headlight switch but still flash with the Signal Stat. I figured I'd run power to the headlight switch, from that switch to the Signsl Stat, and then from the Signal Stat to the parking lights. BUT I can see how to feed power from the headlight switch to the Signal Stat.
I'm also not sure if the red and black wires to the Naco replicas are both hot forthe two different filaments (and so the ground is through the brake light case to the tub) or if red is hot and black is ground or ...?
Help!
Thanks,
P.s. - I've got the Signal Stat 900 wiring diagram and have read whatever I could find on this, but the answers I'm needing just aren't out there.
Tucker
Help!
Thanks,
Tucker
