I went in and tried to fix yours and screwed it up badly. :D Then I decided I could fix it on mine. After that Cj fixed them both. :laugh::laugh::laugh::laugh:
Lol now that's funny
Nice work. I really need more brakes on the Laredo with the 35s. Of course I need an engine first. :D
4 wheel discs are a good thing, you can piece meal back discs for a pretty decent price while you are waiting on the motor. I went with the parking brake on the back of the Transfer Case so I am able to use the whole brake system off the front of my CJ for the rear and its pretty cheap if you dont need a parking brake:chug: If you do need one the GM calipers with the cable parking brake with CJ rotor is the way to go and still cheap :chug:
Looks like fleebay has the correct low range case for sale... And it's mismarked as a later case. Contacted seller to verify, going to put a bid on it :)
You are buying a new Transfer Case ?
You are buying a new transfer case?
Nope the correct low range Nv4500 housing, the one I have is a 97 with the 5.61 gear, the inside of the case is different between the 92-94 and 95-up to accommodate the reverse gear
Ah gotcha should be cool when it's all said and done
Yep should be awesome, I will have a crawl ratio of 99 to 1 with the 6.34 first gear 4 to 1 Transfer Case and 3.91 rear gear
What gears in the axles again?
6.34 trans 4-1 transfer case 3.91 axle 315/70-17 Goodyear Duratrac tire
Gotcha gotcha, what axle do you have in the rear?
Dodge Dana 44 front with Detroit true trac and Dodge 9.25 rear with Detroit true trac and 1350 yokes all the way around
About to narrow both axles to 60 inches and add moser axles shafts
Cool cool man, ditched that AMC20 huh? Lol
Cool cool man, ditched that amc 20 huh? Lol
Lol ya that was a few years ago, it had the 1 piece axles 3.54 gears and a Detroit lunch box locker in it, I already had the AMC360 and knew I would tear up the AMC20 so when I pulled my Dana 44 from my old 83 Dodge I grabbed the 9.25 with it since it's a huge heavy duty axle I knew I wouldn't tear it up in the CJ
Lol ya that was a few years ago, it had the 1 piece axles 3.54 gears and a Detroit lunch box locker in it, I already had the AMC360 and knew I would tear up the AMC20 so when I pulled my D44 from my old 83 Dodge I grabbed the 9.25 with it since it's a huge heavy duty axle I knew I wouldn't tear it up in the CJ
Do you think the 20 will hold up to a AMC 258 i6 / 4.2l , 31 inch tire's and me not really beating on the jeep? I want to do away with the 2 piece shafts..
Do you think the 20 will hold up to a 258, 31 inch tire's and me not really beating on the jeep? I want to do away with the 2 piece shafts..
Oh ya it will be fine, it's a great axle after you put 1 piece axles in it. It wouldn't hurt to weld the tubes to the center housing either, with 31s you should be able to drive it as hard as you want
Is the T-176 a heavy duty Transmission ? That's what it has..
$20.00
  10.0%
