Bad vibration above 1900
- Media
- 1
- california
- 1965 CJ-5 Buick V6 Ford T-18 4-Speed Spicer 20/18,Warn Overdrive Dana 30 & 44 w/Powr-Lok posi / both,4.27 gears 33" tires.
Too true! I will have a professional look closer as I do not have the knowledge for those types of issues. Tomorrow, I'm going to finish cleaning the block. Should I wait to paint till assembled? I'm not painting the intake or timing cover, so I'd have to be careful painting the front right? I can't get paint under the timining cover? Just not sure where to start to get moving before the parts get back from the shop. The whole jeep is caked with grease thicker than poopie from years of bad leaks I assume. What to do?
You need to clean the block and exposed parts best you can..........No paint under the timing cover..........mask off the area's you don't want paint on and shoot it.
You say you have a friend that has knowledge that will help, Hopefully he will also assist you in the assembly of all your new parts. If you have the ability tow the Jeep somewhere and either power wash or steam clean it.
And hopefully you have confirmed what motor & Flywheel you have.
Like I said before go to a local Napa or other parts store and talk to the parts person about the clutch combination you need............not saying you have to buy it there, just get educated!
