im almost done but need your help
rus
MO, joplin
1980 CJ7 iron duke
My lighting was a night mare when i got this jeep its been a long process but I've got it all back to working the way it should. Except for the front turn signals/parking lights. The problem is when the parking lights are off the signals work just fine when I turn the parking lights on the signals still work but the parking light element is to bright to notice the turn signal. I still think this could be a ground issue but the other thing I found out is when I swap the hazard and turn signal flashers nothing works when I swap them back to how they where it goes back to how it was.... Do you guys have any ideas.... I'm so close to being done with this nightmare lol
:)If your parking lights are bright....you have the wires switched at the light socket..............look at the placement of the bulb.......the big filiment is the brake & turn & the small is running lights..........switch the wire.
:D:D:D:D
:D:D:D:D
X2 on what tarry said.
:D:D:D:D
:agree: also
Thanks never even thought of that they where brand new lights from Morris 4x4 might have just got a bad batch or something I will check them out tomorrow and see what happens then
