oil on #5 plug-reposted correct forum
idletinkerer
- Michigan
- 1979 CJ5, 304, T176, D300 Twin stick, power steering, D30 w/discs, AMC20 2pc w/disc conversion, 31" tires, 1 " body lift, YJ modded rollbar all shoulder belts, TJ modded sound bar with dome light, restored hardtop and doors, rear fold and tumble seat.
1981 CJ5 , AMC 304 V8, Delco Remy HEI, edelbrock performer intake, edelbrock 1404 carb, T-176 4 speed, Dana 300 , twin stick, AMC20 rear two pc stock, dana35 front, running 31" rubber. complete frame off rebuild, using 1979 frame and tub.
When i bought it, it did not have the gas tank mounted as PO was repairing frame, which was worthless. I got it cheap, started it on a cup of gas down the carb.
I got it home and ran a new gas line to a 5 gallon can and it started and ran after sitting for two years, as it warmed up it smoked alot out of the drivers side exhaust. Not on startup, but after it warmed up.
8 months later after a new frame and tub, I got it running again, after putting in new valve seals, - (I changed seals with the air compressor hooked to thru the cylinder, no problems, no leaks of air thru valves, all went smooth.) Still smokes.
Here is what I have confirmed.
compression test dry with engine warmed up, AMC 150 psi across all 8. twice. wide open throttle, all plugs removed. Did not perform a wet test.
I performed a block test, with the blue chem in the tester via the brand new radiator, chem stayed blue, did not change to green or yellow, this rules out a head gasket. No cumbustion gases in radiator system.
No blowby thru oil filler or PCV valve, no suction into the intake manifold via the PCV valve hole, no oil leaks anywhere on motor. no evidence any- where of an oil leak or blowby, there is evidence of a rebuild, ie new freeze pluggs and all gaskets look fresh.
Now, why would #5 spark plug be full of oil, exhaust pipe without cats, has black oil leaking in the seams between first pipe to front of muffler, only on drivers side, whitish/blue exhaust drivers side, water vapor and geyish film on inside of tailpipe.
What should I look for before pullin the head- stuck oil ring or bad valve seat/guide?
All help appreciated
idletinkerer
Read more: http://www.jeep-cj.com/forums/f60/5-spark-plug-oily-21749/#ixzz2wkO6lZkA
idletinkerer
