Build Thread Starting from the frame 1977 CJ5
Cat ?!!!!
I know you want it to Purr like a Kitten when you get it running,
But NO CATS Wanted !!!
LOL
Unless it had one in 1977, and you need it for SMOG inspections, .......
Don't Need It !!
Not saying to commit a Environmental Crime, need one only for Visual Inspection?
New, ....They are expensive.
Go to the Junk Yard, ( or your local crackheads car trunk)
get one with the correct in and out pipes, "Rod" the innards out of it, Install somewhere before the muffler, ........
Problem FEEXT. Plus you have to Expansion Resonator in the system.
Cat ?!!!!
LOL
Don't Need It !!
While I enjoy your posts, they are so all over the place.... Why not just reply without the pages of cantour?
It's God's Gift......
But if the Administrator wants it Cut and Dry........
It's going to be a Hard Sell for me,
But I will try
Are you asking about the exhaust manifold or the heat rise? Are they broken? I cannot tell by the picture.
Are you running with the preheat tube connected to a factory air cleaner? If not it is not doing anything and it doesn't hurt to leave it or remove it.
Can someone send me a picture and the measurements of the data plate that mounts on the fire wall please. I found a place that can reproduce them.
Measured from inside fender at the right.
Just install the top of that data plate about 1” below the main wire service entrance hole and you’ll be good to go.
My .02 cents...work on getting the engine running first before you take it out of the frame...much easier to work on when it's mounted in the frame. This will confirm the engine is good and not in need of a rebuild...if it does need engine machine work/rebuild that long lead work can be done while you're working on the frame.
Mike that was my plan, I don't have any way to remove the engine and I have now engine stand So working on it where it is. I do know that the engine was running last spring and I saw a video of it running. Then engine is free and turning. I checked the oil and it is cleaner than the oil in my car. Frame is done. Engine is the last step.
There are a crazy amount of body mount kits but they all use hard poly bushings.
As much as hate to say this the old Jeeps bend and flex even the later years with boxed frames.
So, the only place that I know of that has true rubber kits is Willys Overland.
My .02 and there is nothing wrong with any of the poly kits on the market place.
$45.00
  22.5%
