Build Thread The '80 FrankenJeep frame off reassembly
Either or............but he was adding some Tow hooks off of a Fire Truck he stated..........again I've seen guys pull there bumpers off using there winch or tow hooks if not properly secured.............If there just for show as many are then doesn't matter.
:D:D:D:D
I have used mine many many times with out a problem, they are not for show but maybe I don't get as stuck as you do :D
Hey , glad to hear that.........Hooks are not about being stuck........that's what you have a winch for. I use mine mostly to pull others out and like I said before I've seen many Cowboys out there rip there bumpers right off........happy trails!
:D:D:D:D
:D:D:D:D
Happy trails my friend. Some day I hope to have a CJ as nice as yours :notworthy:
:) I've seen many Cowboys out there rip there bumpers right off........happy trails!
:D:D:D:D
While I have no intentions of working the front hooks hard enough to tear em off, you guys have convinced me to revisit the reinforcing issue. Years ago I watched a guy try to yank a truck out of a mud hole with one hook on the front of his CJ...... When it let go, it went thru the windshield of the truck he was yankin on, thru the back glass, and disappeared into the woods behind the truck.
:grinjeep::biggun::madjeep:
You, The Gun, and Him!
Yup - almost came to fisticuffs. He immediately started offering money for repairs, but in all honesty, I think it was just to keep from having his *** handed to him....
Took the axle housings and new differential guts to my neighbor's house to start working on the regear...... I was fully prepared to be the step n fetch since I know little more than the general process of regarding, and he politely informed me if it was all the same to me, he'd just as soon do it without me - he'd spend too much time talking and not enough working.... So I'm prepping the rest of the stuff off the axles so when the are ready I can begin reassembly.......again.
I thought he was just gonna help - didn't realize that meant do it for me
Exactly what I was thinkin' on doing. New grease might not purge out the old entirely, but better than before. I like, let us know how it works in the end.
While it's still fresh in his mind it would be good to get:
- what your backlash is
- Bearing shim stack numbers for right, left bearing, the pinion and the pinion preload
These are nice to know for future reference. He might not know what the shims are, but he should know the final back lash. He should be in the 0.006 to 0.007 range.
I'll pack the bearings before install, the fill the cavity after I'm done. Figure it wouldn't hurt to hit with the grease gun again after R&P break in lube swap.
He took a ton of notes - As a matter of fact, he's kept the setup numbers for most of the setups he's done at home. Backlash is right at .006 for both, but I don't remember the preload numbers off the top of my head. I've got a couple pics to throw on here later tonight.
shum8 - Very good numbers! You won't notice anything at all, except maybe a tighter feeling rear end.
People, me included don't think of grease as flowing or moving in a bearing type situation like you are working with. But, it most certainly does, grease flows through and around working bearings. Besides the fact that bearing grease gets HOT and darned near liquid.
I got the rear axle put back together this afternoon.... Well, all but the brakes. It's now ready to stick back under the frame. Would have taken pics, but this part was pretty uneventful. I did have an epiphany today. Actually more like a really good idea..... I guess in realville it was just a thought. When it came time to shove the axle shafts back into the housings, I mulled over in my mind how to support the axle so as not to stress the oil seal. Looked all over the garage (and if could see my garage you'd understand what a feat that was) for something just the right height..... Nothing. Then my little 5 watt bulb went off in my head.
As a disclaimer, I would STRONGLY suggest you NOT do this if your axle housings are attached to the vehicle!!
I stood the housing up on its end, lubed up the axle, aligned the backing plate, outer seal, applied sealant to the axle flange and just lowered the axle down into the housing. Piece of cake. I'd like the have those twenty minutes back!
It's looking good :popcorn:
$150.00
  75.0%
