Driveline popping/binding sound with video
Peanut Butter
Full Time Jeeper
- Media
- 37
- Resources
- 1
- Boerne, Texas
- 1979 Jeep CJ7 TH400 Automatic 258 I6 Quadratrac Amc 20 rear & Dana 30 front, 32 x 11.5 x 15 tires. Currently a Complete Custom Rebuild in progress.
Yes, with a Mile Marker Part Time Kit you use regular Transmission fluid.
Now with reference to taking the whole thing apart or just the back half. The Part time kit replaced the diferential that is in the OEM QT. That is the only other part that wears quickly. The slack in the chain could have damaged some of the gear teeth it rides on, but you will be able to see that by just taking the rear half of the case off. So no need to tear the whole thing down. Order a chain from BJ's. When you do they have a special deal that includes all of the seals and gaskets for just a little extra. It is a very good deal. Also order the plastic thrust washer (part #7). These wear out fast too. When everything is in, be sure to read all of the articles on the QT. Look at my build thread. Plan what you are going to do ahead of time. Remove the rear half of the case and replace the chain and the thrust washer. Look for any other damage, teeth of gears, case rub, etc. (If you have any damage, stop, take some pictures, post them or send them to me and I'll help you out.) Use some silicone gasket material and seal everything back up. You should now be able to spin it a little with the transmission in neutral. Poof! You're all done. Time to test it out, or as soon as you get everything back together. I think your problem will be solved. If need be I can send you some more pictures of mine. It's really pretty easy though. Here is another article on the QT you might want to read: Frank's FSJ Garage - The Transfercase and this Original Jeep Quadra-Trac - Tech Articles - JP Magazine
The thrust washer goes toward the rear of the left hand gear set. You can use some grease or Vaseline on it to hold it in place. Don't be surprised if there is nothing there when you take it apart. Make sure you check the case for damage. It is aluminum and can be cracked or damaged very easily. If the chain has damaged the case in any areas, smooth those out and then flush with a little transmission fluid.
out of it with a pry bar and a 2lb sledge hammer to try and break the seal.
