Build Thread The '80 FrankenJeep frame off reassembly
In my next life I want some patience...... looked for weaker hydraulic struts for a while, but figured it was gonna be a :dung: shoot as to whether they worked or not. So, I gathered up the four hydraulics, the original spring cylinders, a hack saw, drill, grinder, sharpie, and a beer.
Since I just finished adding the mounting studs for the hydraulics, and would still like to use a set at some point, I decided to modify the originals. They have a decent amount of rust internally - every compression is followed by a large poof of rust dust. They were scratched up pretty good, so I figured hackin em up wouldn't be the end of the world. The plan was to remove the OEM attachment points from the springs, add the hydraulic ends, and use the, that way.
Drilled a small hole into the aluminum end to assess thickness. Nearly a half inch - good deal. I'll cut the ends off the hydraulics, thread the shaft, drill hole,in end plugs, tap, the screw the ends in and be done. See the problem yet?
Harvested the hydraulic ends only to remember the shafts are hardened.
And I mead HARD. So much for threading those. No sweat. Drilled the ended of the spring cylinders,
Since I couldn't thread them, I needed a mechanical lock. So I cross drilled the hole for a pin
Then hit the shaft with the grinder for a notch
Smoothed up the ends and hit em with a little paint
Inserted the shaft into the crossed drilled hole, aligning the notch with the hole
Drove a nail through the cross hole ( which was almost too tight), and had an OEM spring cylinder with hydraulic cylinder ends.....
Now for the fit test
Yes - I know I have them mounted upside down - but when I drill both ends, I knocked out as much rust as I could, sprayed the interior with WD40, then mounted them upside down to minimize oozing LOL) see the rusty WD40 oozment below?
Best part is, they work like a charm. Almost like they were made to do this. (And my dowel lift gate support Rod went back into the garage
And now for the PSA portion of the post - I would like to invite everyone reading these threads to go ahead and become a financial supporter of the site. I mean, it's like 25 bucks a year. The information I have garnered from this site over the course of my build was invaluable......... and if that's not motivation enough, where else can you go and aggregate the snot outta folks for that small of an amount?
Seriously - the clock is ticking. If we don't step up, this sites a goner.
That was a great fix ! Hard to believe that all came from drinking 1 beer
Nice job for the lift supports. For those who less inclined (nice way to say lazy) I used Stabilus SG304075 with a NAPA knuckle 2-687. If you wanna see the pictures they are on my first thread in this forum. Search for "disaster" and they are posted on one of the last pages.
The beer was just for inspiration - it was a nice bourbon barrel aged stout.
Physically those would fit, but the bolt holes in the top itself on mine are comprised and won’t take a lot it torque on the bolts - when I attached the hydraulics that I had, the hinges wouldn’t hold - way too much force required to close. At some point down the road I’ll see if I can find lighter strength struts
Those are good, another thing I heard about several months ago and is my go to hard beverage when in the mood is Jameson Irish Whiskey CASKMATES STOUT Edition. Maybe try the Cherokee (1996) hatchback had shock ones
I’ll see if I can scrounge one up - sounds tasty. Once warm weather gets here, the stouts an porters get a little heavy. Try one of these - good summer barley pop...
Ooh - they totally slipped my mind. That’s worth a trip to the pick n save for sure....
The ones on the Cherokees are really stiff because the hatch is really heavy.
I was thinking the wife's 96 was pretty light. Cheap *** light hollow fiberglass. Don't remember it being that heavy when I replaced both struts. Maybe the mind is forgetting
Either way I’ll check em out [emoji106]
Over time they do loose their pressure or strength so keep that in mind
I have had 3 Cherokees and was surprised at just how heavy a fiberglass hatch was. I would bet it's at least 3 to 4 times that of a CJ hatch. Just look at the size difference.
I'll take your word. I've never had or lifted a hardtop back window.
What might work is a strut from a Chevy Traverse hood if it is long enough.
Was getting ready to swap the hard top for the softy, but realized I never got the TH hard uppers fitted. The guy I got em from said they were from a YJ - Not. I drilled a new hole for the rear pin, trimmed a bit from the inside flange, and worked out the spacing between the upper and lower.
Taped off the top of the door, inserted the new pins, and laid down three layers of glass. Once that set up, I placed the upper with spacers, made up four rolls of resin saturated matting, and shoved em in between. Had to let that set a while to cure before I removed the upper.
Now all I have to is fill in the voids between the bottom of the upper and new glass bottom. If this works out, I’ll run the half doors year round and just swap uppers.
I have no idea where I sent this from......
So what are you thinking the uppers are from ?
With the rear pin offset I’m thinking TJ
$120.00
  60.0%
